So I got my DSP upgrade kit for D/K40 small machine in and the manual found linked on the forum is missing a lot of information.
There is nothing about the power display, kill switch, or any details of the wiring to the DSP.
Any help would be appreciated.
Tim
DSP upgrade kit for D/K40 small machine -- Help
Re: DSP upgrade kit for D/K40 small machine -- Help
Anyone have any installation information for the Isolated Power Module that comes in the kit?
Tim
Tim
Thank you that is what I needed!
I have a new issue. I got the whole thing installed and I am having two issues.
1: The red light comes on the power supply when the laser should be firing but its not working. If I press the test button on the PSU it work but when I run the program it is not firing.
2: When I am trying to run a test through the LaserCad program it appears that the machine is trying to run a much more intricate cut. I can not see what it is as the laser is not firing but it's not a box.
Thank you,
Tim
Thank you,
Tim
So we resolved the issues it appears. The diagram provided did not show the required jumper for the laser power supply.
Tim
Tim
