DSP upgrade kit for D/K40 small machine -- Help
TimAustinTX
Post by TimAustinTX »
So I got my DSP upgrade kit for D/K40 small machine in and the manual found linked on the forum is missing a lot of information.
There is nothing about the power display, kill switch, or any details of the wiring to the DSP.
Any help would be appreciated.
Tim
TimAustinTX
Re: DSP upgrade kit for D/K40 small machine -- Help
Anyone have any installation information for the Isolated Power Module that comes in the kit?
Tim
TimAustinTX
Thank you that is what I needed!
I have a new issue. I got the whole thing installed and I am having two issues.
1: The red light comes on the power supply when the laser should be firing but its not working. If I press the test button on the PSU it work but when I run the program it is not firing.
2: When I am trying to run a test through the LaserCad program it appears that the machine is trying to run a much more intricate cut. I can not see what it is as the laser is not firing but it's not a box.
Thank you,
Tim
TimAustinTX
So we resolved the issues it appears. The diagram provided did not show the required jumper for the laser power supply.
Tim
