thanks
Gadroc wrote:After you change the home position you have to download the job again.
Gadroc wrote:Sorry I was referring to Position Relative. Make sure it is set how you expect it to be, and then download the job again. Attached are my screenshots of the settings I'm using, and yes as you can see from my thread I've also converted a K40 machine. I noticed you have hardware limit checked on your machine do you have 4 limit switches or just those for the home position?
crozza wrote:Good Stuff![]()
I loose my settings aswell...weird
Gadroc wrote:The manufacturer and user parameters are stored in the DSP and not the software. Every time you open those pages hit READ to read the current settings from the DSP. Also once you make changes you have to press the WRITE button to send the new values to the machine. Also keep in mind that changes on the manufacturer parama will possibly change values on the user parama page.
