LO-X7 autofocus while engraving
geartech
Post by geartech »
Can the X7 autofocus while its running an engraving operation ?
Provided it has the inductive sensor and z table
Re: LO-X7 autofocus while engraving
Without any extra's: NO..
But if you want to spend a little fortune you could try the dynamic autofocus system, although i think it will be too slow for engraving @300mm/sec
When engraving the surface should be flat (within DOF-range) and horizontal.. Then you only need to autofocus once..
