Inside dimensions of 900x600 XY stage
Guldberg
Post by Guldberg »
Anybody have the 900x600 XLE stage, who would like to post the inside dimensions of the XLE900x600 stage? From profile to profile, both width and height.
Re: Inside dimensions of 900x600 XY stage
Sorry for the late reply. I have done a preliminary measurement and the precision should be less than +/- 2mm
Posted two files: Jpeg and Coreldraw X5
XLE90120.cdr
CorelDraw X5 file
(398.66 KiB) Downloaded 261 times
Guldberg
Post by Guldberg »
Thanks Marco
This must be the 1200x900 table.
What I can deduct from this is that the x is nominel + 165 mm and Y is nominel + 160 mm, so the 900x600 table must be around 1065x760 inside dimensions.
Oh...sorry I think I mixed up the diagram. You're right, it is the 1200X900 model.
And yes, you can simply minus 300 on X and 300 on Y should get you closed to the 900x600 stage. I'll try to get the 'blue print' from my manufacturer and once I have it, I'll post it here
I have posted the dimension for XLE600 to XLE1800 to this:
viewtopic.php?f=16&t=1658
Users browsing this forum: No registered users and 60 guests
