Hi All,
I seem to have run into a strange problem. I can't get Lasercad to connect to the AWC608 2012 DSP. I've installed Lasercad 5.93 and Lasercad loads. When I try to connect via USB, it keeps telling me "Communicating Unsuccessful". Here is the info. from my DSP.
Main Board version: 7.12.04.03
LCD Board version: 5.12.2.29
I'm running windows 7 home edition 64bit.
In device manager, there is an unrecognized device: "FT245R USB FIFO"
If I unplug the USB cable from the DSP, this device dissapears so I assume there is probably a problem with the USB driver.
I've tried rebooting and cycling power to the DSP with no success. I've uninstalled Lasercad and Reinstalled, but the same problem persists.
Please Help! Thank You in Advance
Help please. Lasercad 5.93 won't connect to DSP
Re: Help please. Lasercad 5.93 won't connect to DSP
I thought I must have been missing something. I'll try that tomorrow. Thank you so much, Marco.
