"X Y Axis home on power" broken?
Greolt
Re: "X Y Axis home on power" broken?
Post by Greolt »
Tech_Marco wrote: So far, you're the only one want the XY limit switch to be disabled which is considered a very odd 'operation' for the laser machine.
That "Odd operation" was part of the software ever since I purchased the AWC608. It has been arbitrarily crippled in a recent release.
If you look at the LaserCAD software you will see that the selection box is still there where it has always been. See pic.
I am not sure how I can be "the only one who wants it". It was put there by whoever wrote the software.
You have all the links I sent you. You can test each one and found out which OS work for your particular interest.
Unfortunately I did not keep the old versions of the software. I thought maybe you had access to them.
Perhaps another AWC608 user will read this post and help me out with previous versions. PLEASE. :)
I found that the more flexible we're to allow customer request, the more trouble we're encountering. Seems that the request is never satisfied and fulfilled. It give me a lot of difficult to deal with the supplier as I'm always being blamed by both parties; user and the programmer. That' suck, isn't it :(
Yeah that sucks.
But we have no where else to go. We purchased the AWC608 from you, and have no other access to the manufacturer.
Tech_Marco wrote: Well, out of frustration and reluctance, he worked out another patch to disable any movement when power on with XY limit switch disabled. He warned that doing so is very dangerous as there is no limit protection so if anyone have art work exceed the work area, both XY will slam to the side and may damage the XY stage. I'll test the OS before I send to you.
If you could send me the patch that was written to fix this, I would very much appreciate it.
Thank you,
Greolt
home on power.jpg (44.81 KiB) Viewed 1506 times
Tested a new OS patch that allowing to disable XY home on power seems working properly, at lease it worked right on my machine. I'll request a V8 version later.
Greolt, see "PM" I sent you. An attachment with new OS ready for you to test
Keep it safe as I don't keep track of what change being made on the patch.
This patch really put me in a position that I"ll say "not easy" with the programmer.
Unless there is a 'bug' or critical issue, otherwise I will not go for another try for making any change on the limit issue.
Please understand that I been tried very hard and I don't want to ruin the relationship with "Li"
Greolt
Post by Greolt »
Patch seems to be working OK
Thank you
Greolt
Great! I'm so glad it worked out for you.
What a big release on my shoulder :lol:
