I Have a request for a new feature which is often present in machines from big companies.
When a circle or a square is lasered, the laser punches the hole on the vector line and then drives along the vector.
Is it possible to implement that the hole is punched near the vector line and then the laser drives along the line?
I made a sketch to show what i mean: its a poor sketch but one should get what i mean.
https://www.youtube.com/watch?v=pjUa3x31DK8 in this video you can also see it from second 5
Why do I request this feature? When plastic without protection foil or wood is cut, the laser leaves ugly marks on the surface which can hardly be removed.
It takes a lot of time to cover the plastic sheets with a protective foil, so it would be much easier if the DSP supports this feature.
Here is a sample (large pictures)
http://imgur.com/SHw0T1J
http://imgur.com/SsdxTBw
greeting, Chuleo
