this file crashes lasercad upon import
andyseubert
Post by andyseubert »
it's a dxf file exported from cambam. delete the .zip extension from the filename. It's not zipped..
Any suggestion why this happens and how I might fix it ?
MC_Escher_single_lizard_tile.dxf.zip
(16.79 KiB) Downloaded 116 times
Greolt
Re: this file crashes lasercad upon import
Post by Greolt »
I don't know what was wrong with it.
Here it is as ai
MC_Escher_single_lizard_tile.ai
(6.47 KiB) Downloaded 107 times
andyseubert
I got it to work by opening the dxf in autocad then saving it from there to dxf again. Then lasercad would open it.
I also have had no luck opening .ai files directly from lasercad. Is there a trick?
Guldberg
Post by Guldberg »
DXF's from illustrator always works if you do the following:
Release clipping mask
Release compound path
Ungroup all
Some of the above sometimes have to be done several times
Greolt
Post by Greolt »
Have LaserCAD open and "Import" the file.
andyseubert
It is not possible to File>Open a .ai file so yes, "import" fails mostly.
Post by waltfl »
HI
yes this is something for marco to look in I try this too even if in the supported file .ai is there it will tell "parsing" but then nothing comes up.
maybe lin can fix it.
quote="andyseubert"]
It is not possible to File>Open a .ai file so yes, "import" fails mostly.[/quote]
