Cannot find the Corel direct output file AWCLaserCut.AWC_In
jimsbox
Post by jimsbox »
I have successfully upgraded my K40 to DSP and have successfully run the box test but cannot find the macro AWCLaserCut.AWC_Init to install in Coreldraw so cannot output to image.
Where can I get the file? I searched my whole disk drive for AWCLaserCut and nothong. I also looked in the Lasercad directly and did not see anything like it.
Thanks in advance
Re: Cannot find the Corel direct output file AWCLaserCut.AW
Post by waltfl »
hi there
if you install lasercut you need to select lasercut for corel ( scroll on the initial screen)
then open a new CorelDraw file, then go to tools then scroll down to run macro there click on the arrow and on the list you see awc start click on it then ok and then close CorelDraw and reopen there you should see the lasercut icon
jimsbox wrote:I have successfully upgraded my K40 to DSP and have successfully run the box test but cannot find the macro AWCLaserCut.AWC_Init to install in Coreldraw so cannot output to image.
Thanks in advance
jimsbox
Post by jimsbox »
That is the problem, does laser cut come as a subset part of lasercad? I thought I would be able to output directly from coreldraw 12 using a macro to the laser engraver. Am I mistaken or do I need to get something else from Marco?
By the way, thanks for replying.
Jim
Post by waltfl »
hi jim
no you can not send your work file to the laser you allways have to go over the lasercut program.
jimsbox wrote:That is the problem, does laser cut come as a subset part of lasercad? I thought I would be able to output directly from coreldraw 12 using a macro to the laser engraver. Am I mistaken or do I need to get something else from Marco?
Jim
jimsbox
Post by jimsbox »
So how can I get the lasercut file?
Post by waltfl »
Hi there
here comes picture from the setting for macro
first open a new CorelDraw file, then follow the picture after them then close the file and then open a new file again and you will see a little icon mostly blue drag it to the top line box ( see picture) and you are all set.
now if you open your file then just click on this icon and the file will be transferred to the lasercut program,
jimsbox wrote:So how can I get the lasercut file?
corelmacropart3.pdf
(278.3 KiB) Downloaded 378 times
corelmacropart2.pdf
(289.74 KiB) Downloaded 395 times
corelmacroset1.pdf
(300.43 KiB) Downloaded 390 times
