Hi David,
liaoh75 wrote:
One correction on my previous post. My setting is one pulse = 10um oppose to my previous setting of 1 pulse = 1um of motion effectively reducing my resolution by a factor of 10 to get a pretty waveform from the DSP. I feel that this resolution is more than adequate so no complaints there. I'm even willing to bump it up to 1 pulse = 20 um if that solves this problem. Could you please ask the engineers if this would help.
David
Yes and no.
The controller is absolutely able to calculate high resolutions like 1µm/step, but:
A very high resolution will slow down the speed of your stepper or servo motors.
The AWC-608 is able to drive the "pulse-output" for X-,Y-,Z-,U-axis with 150kHz maximum Frequency.
If your resolution is 1µm/step, the pulse-frequency will be 150kHz at 150mm/s. By choosing a higher speed your machine will loose steps.
You can calculate this very easy by yourself for different resolutions:
max frequency (Hz) x resolution (m/step) = speed (m/s)
150.000Hz x 0,000001m/step = 0,15m/s = 150mm/s
After changing the resolution up to 10µm/step your max speed is now 1500mm/s. (from controllers side not your complete system!)
There can be more problems with stepper driver, motor mechanics ...for sure.
My tip to Charly: try to reduce the space_speed for your system. This could be a reason for your problem.
Good luck.
Greetings from Germany
Diemo
