New Issue - 1/4" Cut at start of every job
Gadroc
Post by Gadroc »
I adjusted my stepper drivers down to 16th steps instead of 8th steps tonight and I started noticing a weird behavior. My DSP now cuts a quarter inch line straight up from the origin before every job. Has anyone else seen this and have any suggestions for it?
I double checked my manufacturer parameters and I'm still set to low level effective and glass tube.
Re: New Issue - 1/4" Cut at start of every job
Post by baccus61 »
Hi Gadroc,
Check the setting "automate cut direction" and turn it off and see if that helps. It should be in the "Download" popup when you process a file and send it to the LCD screen interface. This setting does weird things.
Gadroc
Post by Gadroc »
Unfortunately that didn't change anything.
Gadroc
Post by Gadroc »
So it looks like the bug is with the DSP controller and not the LaserCad software. After a little more experimenting I found that it will fire the laser based on the keypad settings for about a quarter inch towards the Y home at the start of every job from that jobs origin. Work around is to set power 1 on the control panel to 0 so the laser doesn't fire and set the control mode to soft.
Post by baccus61 »
Yes. I use the "soft" control method too. It's just easier as you use the mouse for most of the setting procedure and you don't get too confused.
Gadroc
Post by Gadroc »
That's the problem. I have the machine set to soft controls.
Here is what happens at the start of each job:
  1. Moves to the origin.
  2. Laser power is set to whats on the control panel display.
  3. Jog in the negative Y axis for about .250"
  4. Turn off laser
  5. Processes the rest of the job as expected under soft control
The problem lies in it should not be doing sets 2-4. With steps 2-4 I have to set the control panel power to 0 to prevent marring of my work material where I don't want it. This prevents me from using the keypad to set power / speed when experimenting with a new material. I have to go back to the computer and re-download the job with the new settings. In addition the control panel power gets reset to a default every time I turn on the machine, so if I forget to reset it to zero I can loose a piece of material.
Gadroc
Post by Gadroc »
Ok. Some further troubleshooting has narrowed down the scenario.
Steps to reproduce:
1) On the DSP set config mode to soft layer params
2) On the DSP set origin mode to key
3) Open lasercad and draw a 50mm x 50mm circle
4) Set cutting power and speed in laser cad
5) Download job to DSP
6) On DSP keypad set laser1 power to anything that will trigger the laser to fire (above your minimum power)
7) Jog the laser head with keypad
8) Press origin on the DSP
9) Press start
Result is you will get a small cut at the origin and then it will start the circle. Repeat steps 6-9 again but set power to 0 and the line will be gone as the laser can't fire at 0 power. The power seems to be locked in once you hit the origin button as once you've pressed origin with zero power it stays that way even if I set a new power, but as soon as I hit origin with power above 0 it cuts this line at the origin.
Gadroc
Post by Gadroc »
Marco.
Have you guys been able to do anything about this one. Replicate it or fix it?
I almost destroyed hours of work last night when I forgot to set power to zero before hitting origin.
mattrsch
Post by mattrsch »
I recently got my DSP up and running and I am having the same issue. Has there been any work on a fix for this?
Gadroc wrote:Marco.
Sorry I didn't see this post. I was in Vagas during that time. I can't try it as all my DSP card sold out. I have to wait for the new card coming on next week. I did mention a 'tail' light issue to the programmer but not sure if it's related.
Try download the newer software and upgrade the mainboard with the patch see if it still happen. Better shoot me some pictures to see
Gadroc
Post by Gadroc »
Will do I'll try it again tonight after I upgrade.
Gadroc
Post by Gadroc »
Unfortunately it's still doing it. Exact same behavior as described in this thread above and this video.
Gadroc wrote:Unfortunately it's still doing it. Exact same behavior as described in this thread above and this video.
Do you have a digital volt meter?
If you do then try to measure the output from the TTL port vs Ground at the moment of the 'extra' light happening.
Also, do you have other laser power supply can bu used for testing?
Gadroc, what is the board version? 10.19, before or after??
Menu-》system version-》main board
Gadroc and mattrsch, what kind of power supply you guys are using?
We couldn't duplicate the problem. The enginner follow your instuction but he couldn't get that extra line like what you had.
Did you two upgrade the mainboard yet beside the LaserCad v5.83?
