twehr
Re: Converting K40IV machine
Post by twehr »
TeacDance wrote:Now all connected but some problem i have
how i can go change the parameters? i put phcad password but always it say password error!
is password change?
other problem is limit switch
What password are you using? The correct one is ph123
TeacDance
Post by TeacDance »
is password change?
Thaxs that workin i try wron gxfc88
do you have limit switch diagram now i when i push switch led go on is that correct?? when i drive home motor not stop? what my connet wrong?
TeacDance
Post by TeacDance »
is password change?
Yeppii now limits working next laser :)
TeacDance
Post by TeacDance »
TeacDance wrote:
is password change?
Now all working allmoust right ;) only arrow direction is wrong but if i change direction my reset direction change same is that bossible change some another way?
TeacDance
Post by TeacDance »
Couple pictures of my conversion... do i have to use that big resistor look picture 1567 right side??? now it's not use but it's working
TeacDance
Post by TeacDance »
TeacDance wrote:Couple pictures of my conversion... do i have to use that big resistor look picture 1567 right side??? now it's not use but it's working
anybody know that resistor?
twehr
Post by twehr »
That was part of your original power for the laser tube. Don't need it with standard laser power supplies (like the ones from LightObject and other sources). Take it out and forget it.
TeacDance
Post by TeacDance »
Ok..
TeacDance
Post by TeacDance »
Hmm is possible to use phcad without machine?? It's say Connect machine "OK" and "CANCEL"
TeacDance
Post by TeacDance »
What meaning when laser display say " Not enough extend space please esc"
twehr
Post by twehr »
TeacDance wrote:What meaning when laser display say " Not enough extend space please esc"
Means you are too close to the edge of your useable work area for the speed you are wanting to engrave. To engrave, it takes extra space before and after the x sweep to get up to speed. Move your origin so you have more room to left and right of engraved area.
Also, you can increase your acceleration speed. The faster the acceleration, the less room necessary to get up to speed. Acceleration speed should be in the 8000 mm/s/s range. If you are already there, move your origin so there is room to left and right of engraved area.
See my original post and diagram on this subject:
viewtopic.php?f=8&t=277#p654
TeacDance
Post by TeacDance »
Ok that is my problem but now it's solved :)
Today i made new control panel holder my wood router here is couple pictures
TeacDance
Post by TeacDance »
Today i do 30 pcs customer job and earn little cash back
First cut wood router basic instrument base and next burn laser detail. meter use in sauna ;)
I'm so glad to see that the DSP is working. Great job!
May I ask you a favor. Since so many folks bought this D40 machine and having trouble with it's own software. Many of those folks want to upgrade by installing my DSP. Would you you post the parameters setting here like the pulse, steps, bed size... I'm sure the motor is identical as this D40 was made by ShenHui in China. As matter of fact, I'm testing a card with the D40 X,Y motor rack.
Thank you
One more thing, please post the wire diagram to the TB6560 driver and the Limit switch as well
Cheers!
