Cut problem
TeacDance
Cut problem
Post by TeacDance »
What make this happend? one side is ok and other is not vertical
http://1drv.ms/1Iw2XCf
Re: Cut problem
Post by Techgraphix »
I had exactly the same problem.
Just align the lasertube and all the mirrors properly and your problem is gone..
TeacDance
Re: Cut problem
Post by TeacDance »
Techgraphix wrote:I had exactly the same problem.
Ok i have to try alignment again
TeacDance
Re: Cut problem
Post by TeacDance »
Re: Cut problem
Ok, can you confirm that it was the alignment?
TeacDance
Re: Cut problem
Post by TeacDance »
Techgraphix wrote:Ok, can you confirm that it was the alignment?
yep
