What make this happend? one side is ok and other is not vertical
http://1drv.ms/1Iw2XCf
Cut problem
TeacDance
Re: Cut problem
I had exactly the same problem.
Just align the lasertube and all the mirrors properly and your problem is gone..
TeacDance
Re: Cut problem
Ok i have to try alignment againTechgraphix wrote:I had exactly the same problem.
TeacDance
Re: Cut problem
Ok, can you confirm that it was the alignment?
TeacDance
Re: Cut problem
yepTechgraphix wrote:Ok, can you confirm that it was the alignment?
