When you make a change to one of the machine parameters thru
Lasercad and click" save", do the same parameters change on the dsp display or do you have to enter those indipendently? I noticed the "apply" key is not functional? Is that mormal?
Thank you!
parameter settings dsp display and thru lasercad.
Re: parameter settings dsp display and thru lasercad.
After Save, you need to 'Reset' the DSP by press the "Reset" button on the DSP or on LaserCAd
The datum button on laser cad is the reset button?l
Yes. Or, the "RESET" button on the LCD panel
I'm able to jog the gantry from both the computer and the lcd panel.but I still get an error message when I try to send the cut file to the dsp or when I copy it to the thumbnail drive and then try to run it..although a preview shoshone up on the lcd when using the thumb drive.. when I try to cut the file I get the error message. I will email you some screen shots so you can look at the error messages and the machine settings.
Thanks.
Thanks.
