Mini rotary
scottbgv
Mini rotary
Post by scottbgv »
What is the wiring for the mini rotary.
Re: Mini rotary
Try this one:
viewtopic.php?f=16&t=1493
scottbgv
Re: Mini rotary
Post by scottbgv »
I just want to know what wires to hook up and in what order.
Re: Mini rotary
If you doenload the PDF file, it show you the connection of a motor and the motor driver.. It is the same as connection to the X or Y axis. Just ignore the motor controller and hook it up to the DSP instead
scottbgv
Re: Mini rotary
Post by scottbgv »
Thank you i seen it that time!
scottbgv
Re: Mini rotary
Post by scottbgv »
i hooked it up to my m415b stepper control and did not get any movement. do i have to use that stepper control?
Re: Mini rotary
Did you use the DSP to control movement? You need either the DSP or a motor controller board. As I said, it is exactly like driving the X or Y axis
Re: Mini rotary
Post by Techgraphix »
Maybe of any interest: i have a fourth stepperdriver which is normaly in disabled so i can dis/connect my rotary while the machine is on. With a switch near that connector, i enable that drive, make the Y-drive doesn't receive pulses anymore (dir/step) and make a led on the front turn from blue to red..
the advantage of keeping the Y-drive alive is that the bridge is hold into place because the motor is still powered.
I used a small piece of TTL-Logic to do that all for me. It also switches the Z to U while the job is running so i can raise the table in steps when i want to do a multi-pass..
scottbgv
Re: Mini rotary
Post by scottbgv »
I unplugged one of the axis and plugged the mini into it and turned the laser on. when the head was homing both the mini and the laser head should of moved. i hit the end stop switch my self to say it was homed it set to a origin. then i played with the control on the dsp which should of moved the mini's motor. i had no movement at all.
it probably dont help that the new dsp never completely set to english. Only part that is english is the program on the computer. the dsp itself is still unreadable.
scottbgv
Re: Mini rotary
Post by scottbgv »
ok i need help i need the new dsp i got from you guys to be in english. i have uninstalled and reinstalled it on widows 8 a few times never got it to work.then i got the old laptop out and installed it there. I got the program in english on the lap top but never got the dsp into english.
we can worry about the mini next
Re: Mini rotary
Press "Menu" on the LCD unit. Scroll down to the 2nd of the last and it should be language setting
It should be mentioned on the AWC608 manual
scottbgv
Re: Mini rotary
Post by scottbgv »
Thank you so much!!!! that is great!!! any way you can point me into the right direction on the mini?
would it be best to buy a separate driver? which do you recommended?
Re: Mini rotary
Here some pics of my circuit.
scottbgv
Re: Mini rotary
Post by scottbgv »
awesome! but i dont understand any of that. i am not good on wiring or reading the diagrams i admit that . i really learn from watching i am sorry
so do i need this to make the mini work?
Re: Mini rotary
I will this board for the mini-Z
Using DSP is OK but it is not convenience as using an external board.
http://www.lightobject.com/Stepping-mot ... -P729.aspx
