Help with my JLD612 wiring
bullka
Post by bullka »
I need help to make sure I am using the PID correctly.
I am using the PID to control a fan that will stoke my fire box on my smoker.
Here is the fan that it will be controlling.
http://www.surpluscenter.com/item.asp?i ... e=electric
The face of the fan actually reads.
115vac, 60Hz, .240amps, 19watts
Can I hook the fan directly up to the PID if so to what input? Or do I need an SSR, if so what size?
Also do you think I need a fuse on the power-in line? If so what size?
Thanks for your help!!!
Jarod
Re: Help with my JLD612 wiring
Please download the manual and follow the instruction to program the controller. Please look at relay connection diagram that I posted on this forum. The controller can drive up to 3A device by it's internal relay.
bullka
Post by bullka »
Thanks for the tips, do you know if an SSR relay like this will work for my application?
http://cgi.ebay.com/Brand-New-Solid-Sta ... dZViewItem
Features
Model: HHG1-1/032F-38 20Z
Voltage rang: 3-32VDC 3-14VDC
Current rang: 6-3.5mA
Make Voltage: 3VDC
Break Voltage: 1VDC
Opposite Voltage: 32VDC
Load Current range: 10,15,20A
Load Voltage range: 24-440VAC
Voltage Drop: <1.6VAC
Switching Time: <10ms
Leakage Current: <10mA
Insulation Voltage: >2500VAC
Ambient temp: -25 - 70 oC
Thanks again!
You don't need a SSR as the built in relay can support up to 3A. Your fan is running at 19W (0.24A). Seems you don't know electronics at all, I suggest you should get someone who know basic electronic to help you setup the controller
