I need help to make sure I am using the PID correctly.
I am using the PID to control a fan that will stoke my fire box on my smoker.
Here is the fan that it will be controlling.
http://www.surpluscenter.com/item.asp?i ... e=electric
The face of the fan actually reads.
115vac, 60Hz, .240amps, 19watts
Can I hook the fan directly up to the PID if so to what input? Or do I need an SSR, if so what size?
Also do you think I need a fuse on the power-in line? If so what size?
Thanks for your help!!!
Jarod
Help with my JLD612 wiring
bullka
Re: Help with my JLD612 wiring
Please download the manual and follow the instruction to program the controller. Please look at relay connection diagram that I posted on this forum. The controller can drive up to 3A device by it's internal relay.
bullka
Thanks for the tips, do you know if an SSR relay like this will work for my application?
http://cgi.ebay.com/Brand-New-Solid-Sta ... dZViewItem
Features
Model: HHG1-1/032F-38 20Z
Voltage rang: 3-32VDC 3-14VDC
Current rang: 6-3.5mA
Make Voltage: 3VDC
Break Voltage: 1VDC
Opposite Voltage: 32VDC
Load Current range: 10,15,20A
Load Voltage range: 24-440VAC
Voltage Drop: <1.6VAC
Switching Time: <10ms
Leakage Current: <10mA
Insulation Voltage: >2500VAC
Ambient temp: -25 - 70 oC
Thanks again!
Features
Make Voltage: 3VDC
Break Voltage: 1VDC
Thanks again!
You don't need a SSR as the built in relay can support up to 3A. Your fan is running at 19W (0.24A). Seems you don't know electronics at all, I suggest you should get someone who know basic electronic to help you setup the controller
