I need help verifying jump when setting change on LCD panel
Hi all,
I need help from some people to verify if it is just my LCD panel from the 2012 DSP what create A JUMP when I change the setting speed and / or power.
the situation is the following :
I download a job from lasercut 5.83 to the machine and start then I realize that the settings does not bring what I expected .
then I hit the pause start botton on the display and change the setting to what I think is right and hit the start botton again and there the laser starts further right then where it stop
I could not attached the file " LCD test1" as a sample for someone to try because the extension PWJ5 is not allowed why is this not allowed it is the the extension for the lasercut 5.83 it would make it much easier for tresting and comparison.
so I have attached a picture how the picture looks at the lasercut what is used it is a normal 8bit greyscale picture and dithered in lasercut . I also attached the picture how the result looks.
I would apriciate all comments
thanks
thanks
Re: I need help verifying jump when setting change on LCD pa
Extension ".pwj5" just added. So you can add LaserCad work file as an attachment
- test.pwj5
- (56.05 KiB) Downloaded 353 times
Hi marco
excellent thank you
excellent thank you
Tech_Marco wrote:Extension ".pwj5" just added. So you can add LaserCad work file as an attachment
Hi all
here are the work file for testing
here it goes again
The extension pwj5 is not allowed.
hurray it worked
here it goes again
hurray it worked
- LCDtest1.pwj5
- (2.98 MiB) Downloaded 368 times
Hi
here is the lasered picture done without changing the settings on the LCD panel.
speed = 300
power = 8% ( 3mA)
scan gap = 0.06
dithering in LC 5.83 = 0.2
speed = 300
power = 8% ( 3mA)
scan gap = 0.06
Programer Li
å‡级主æÂ¿程åºÂÂå°±å¯以解决这个éâ€â€Ã‚®Ã©Â¢Ëœ
Programer Li
6.11.11.9 之å‰ÂÂ的版本有æÂ¤éâ€â€Ã‚®Ã©Â¢Ëœ
Hi marco
thats a good one . I can not reed chinese could you please translate this??
thanks
thanks
Programer Li wrote:å‡级主æÂ¿程åºÂÂå°±å¯以解决这个éâ€â€Ã‚®Ã©Â¢Ëœ
Hi marco
I just used the bing translater and it comes out that the programmer said this is a probleme with boards prior to 6.11.11.9 and a upgrade of the board would solve the probleme.
thats good and fine but how do I upgrade what programm or patch?
the two last ones did not work it only brought the message "upgrade error".
what now? is there another upgrade what you can send me maybe one what also let me download workfiles from the USB stick? because the DSP recognize the usb stick with the upgrade files on it I even used it put a work file on it what the LCD shows but I can not open or work with it
thanks for your help my friend
Programer Li
进入Menu->Memory manage->check memory,然åÂŽ按Lcdé¢æÂ¿的"enter"éâ€Â®ã€‚è€ÂÂ心ç‰待主æÂ¿check memoryåŽ,å†ÂÂ试çâ€Â¨U盘å‡级.
Programer Li
å¹¶ä¸â€Â把U盘格å¼ÂÂ化为FAT32æ ¼å¼ÂÂ
HI
I did this allready a few times even have reformated the memory.
thanks for the respond
Programer Li wrote:进入Menu->Memory manage->check memory,然åÂŽ按Lcdé¢æÂ¿的"enter"éâ€Â®ã€‚è€ÂÂ心ç‰待主æÂ¿check memoryåŽ,å†ÂÂ试çâ€Â¨U盘å‡级.
I formated the USB stick with FAT32 too no change.
the probleme is that I can see from the USB stick with the last patches the menue it shows
the workfile but brings error after selction
but if I take a new USB stick format with FAT32 and put a work file on it and download them the message no U disk comes up,
but if I put the patch file on it the same stick will recognize the USB stick show all the files from patch and the work file too but after selecting the workfile the error message comes up here too.
Programer Li wrote:å¹¶ä¸â€Â把U盘格å¼ÂÂ化为FAT32æ ¼å¼ÂÂ
Hi
it was a very bad advice to check memory because I did it again nothing vame up but all my workfiles was deleted
now I have to start over again
