I have a 35W power supply. It looks like the first picture in this thread
forum/viewtopic.php?f=16&t=18
I don't have a black negative return wire. The manual for the power supply does not give the pinout for the black terminal block. Can you confirm my assumtions.
From left (next to wall) to right
Label / function
FG / AC Ground
AC / AC power
AC / AC power
Not Labeled / Tube Negative Return
Does it matter which AC terminal is line and neutral?
Is 18AWG stranded wire acceptible for negative return?
Negative return wire from tube
bdring
Re: Negative return wire from tube
Doesn't matter which one is "L" and which one is "N". AWG#18 is more than enough. Current is as low as 30mA, so a AWG#24 is fine
