LaserCAD Auto Order function not working properly
hilo90mhz
Post by hilo90mhz »
I am using the newest version 5.77 with DSP 2012
What I have is a jigsaw puzzle cutout that needs to be cut from the center out or the pieces will not be cut properly..
There are 87 individual cuts in the "manual order" window.
I try to use the "auto order" function at download time(and before) with the "inner to outer" boxed checked. (I have tried all the combinations of these check boxes) And no matter what I do it never starts cutting in the middle of the design.. Always on the top left side.
Any ideas?
I have tried manually re-ordering these cuts but it is mind numbing work and I gave up after 5 minutes of rearranging them. Should take my computer .01 second.
Here is the file I am trying to cut: http://www.hilo90mhz.com/projects/laser ... uzzle.pwj5
Chester
Re: LaserCAD Auto Order function not working properly
I have no problem to cut it. I'll post a video later
Update: I oversight your issue about not being able to cut in the middle. Will try again later
But I did made a video to show your puzzle on K40. It sounds like a "machine gun" :lol:
http://www.youtube.com/watch?v=RHOLOZtF1WA
