Hi,
I would like to connect the cover switch and auto focus to the 2012 DSP.
The current wiring diagram download/file.php?id=595 doesn't show what any of the input pins do.
Does anyone know which input to use?
2012 DSP - wiring (cover switch, auto focus, etc)
Re: 2012 DSP - wiring (cover switch, auto focus, etc)
Anyone have this info? This seems like basic stuff - why do we not have this available?dwessels wrote:Hi,
Check page 25 of the AWC608 manual. It tells you the appropriate pins for the various optional safety switches. All switches should short the appropriate pin to ground for triggering, but pay attention to what bringing the pin low does. Some of the switches you'll need to use normally open and others normally closed.
