Slave Motors
aerostar
Slave Motors
Post by aerostar »
I am building a large format laser (2000 x 3000 mm) and need to slave 2 motors for Y axis.
Any idea on how to wire to the DSP board and how to set the software (PHCad)?
powerfade
Re: Slave Motors
Post by powerfade »
I actually asked the question awhile back when I was building my machine. There is probably a small thread about it somewhere. Unlike Mach 3 you don't need to set up a slave axis. The DSP is strong enough to drive both motors off of the same y step and dir. Hope that helps.
I found the link.
viewtopic.php?f=8&t=405&p=1382&hilit=second+motor#p1382
aerostar
Re: Slave Motors
Post by aerostar »
Thanks, this should work.
