Simple soluton for CO2 water cooling
Posted: Thu Jun 02, 2011 9:29 pm
I just imported some small water cooler box and I think it's a pretty good idea to use it for CO2 laser cooling, as long as the laser is not running 24/7 or in mass production. See pictures. This is a simple solution for now. I'm developing a high efficiency water cooler for Co2 and CNC machine. It's an "Active" cooling system with cooling effect other than this passive type.
If this project success, then I'll go for the next one: YAG cooler. The requirement of "YAG" laser cooling is more critical than a regular CO2 laser as the temperature need to be +/- 1 degree. Wwill see
