If this project success, then I'll go for the next one: YAG cooler. The requirement of "YAG" laser cooling is more critical than a regular CO2 laser as the temperature need to be +/- 1 degree. Wwill see
Simple soluton for CO2 water cooling
I just imported some small water cooler box and I think it's a pretty good idea to use it for CO2 laser cooling, as long as the laser is not running 24/7 or in mass production. See pictures. This is a simple solution for now. I'm developing a high efficiency water cooler for Co2 and CNC machine. It's an "Active" cooling system with cooling effect other than this passive type.
twehr
Re: Simple soluton for CO2 water cooling
How soon? How much?
Hello Tim:
The parts for the simple solution are all ready and available on my website: http://www.lightobject.com/Cooling-C52.aspx
The chiller that I'm working on, I guess it will take about 1 month for the prototye built up and then it will take about 2~3 for the production.
By the way, the new DSP card design should be ready soon. I mean the Lite version one and now they asked me for a design of the LCD panel. You got any idea? Or, a request from folks and whoever desgin accepted, then I take off $100 from the purchase for the new card?! Sounds good?
