By the way, I ordered a few heat sink for SSR range from 25A to 80A. It will come in about 7~9 days
Also, a batch of cooling fan also will come with the shipment. They are 9cm, 12cm, and 14cm (monster) DC 12V fan. There are air tubing and connectors also in the order. I found that it's good for water transfer as well. There are 12mm, 10mm, 8mm, and 4mm tubing and a bunch of connectors.
Picture shows a heat-sink for 25A SSR.
Heatsink for 25A 60A and 80A SSR
