2 current measurements with one 5740A meter
don0101
I have 2 AC currents to be measured. I intend to use a 100A:5A AC current shunt on each wire. Can I use a Double Throw switch to switch one 5740A meter between the 2 shunts without causing damage to the shunt that is not connected to the meter? Thanks.
Re: 2 current measurements with one 5740A meter
Yes you can. It won't damage the C.T. (current transformer) but both C.T. must be matched in size
Users browsing this forum: No registered users and 65 guests
