JLD612/PT100 EEEE
x2b
JLD612/PT100 EEEE
Post by x2b »
I ordered the JLD612 and the the PT-100. I can't get the controller to show anything but EEEE (or EEE.E). I hooked the red wire to terminal 10 and the two blue wires to terminals 8 and 9 (actually, I tried all permutations). I set IntY to P100 (and also tried P10.0).
The only thing that does seem to somewhat work is setting IntY to K (at that point the PV value shows something that seems correct).
Am I doing something wrong or do I just have a defective PT100?
Re: JLD612/PT100 EEEE
Red to #8 and two blue to #9 and #10
Make sure that you're configure the controller for "PT10.0"
x2b
Post by x2b »
Thanks Marco.
Tried that as one of the permutations before, and just tried it again. Same results.
I think the problem is faulty probe. Do you have another probe that you can give a try?
x2b
Post by x2b »
Thanks Marco. I send a note to contactus to understand how I get it replaced.
x2b
Post by x2b »
Just received the replacement probe. Problem resolved. Thanks!
ClarencePJ
Post by ClarencePJ »
Reddish colored in order to #8 as well as a couple of azure in order to #9 as well as #10
Make certain that you happen to be configure the controller intended for "PT10. 0".
______________________________________________________________________________________
http://www.realtests.com/
