I have one of these I just installed for Sous Vide use with PT100 and it works but temp reads ~3-4 degrees F low.
I have tried it with other thermometers and in ice and boiling water. I have also used 2 different PT100 and done AT.
Is there a way to tell it to shift some number of degrees?
Cllibrate JDL612
Re: Cllibrate JDL612
Set the setting of "PSB", the error sensor error see if any number put down. If it show 0, then you can add 3 to offset the error
See manual table 1
See manual table 1
