LO X7 upgrade for K40 with MYJG40W laser power supply wiring diagram
Griff7166
Post by Griff7166 »
I have purchased the Lightobject k40 X7 upgrade. I need help with wiring on the Laser power supply to the controller. my laser power supply has these connections from left to right
L- FG AC AC G P L G IN 5V 24V G 5V L
Can someone help me on this I am using a separate 24v power supply and I cant figure out where the TTL and PWM from the controller plugs in to the Laser power supply.
Re: LO X7 upgrade for K40 with MYJG40W laser power supply wiring diagram
Here is the manual for connection: viewtopic.php?f=93&t=2484
You don't need to use the 5V or 24V DC power supply from our laser power supply if you have a separated DC24v dc source (better this way)
What you need to make it work is have these four pins connect: "L Wp Gn In" where L is TTL low signal, Wp= water protect, Gn= Ground, In=Input
Wp must be grounded in order to enable the laser power supply. Usually, you connect it to a water protection sensor.
Have fun on your laser!
LightObject
