I'm baffled by an issue that has arisen. When I create an image in CorelDraw then use the macro to open up LaserCad, then download it to the LO-E5 controller, then run the job, the image is mirrored when I don't want it to be mirrored. If I create an image in LaserCad and send it to the controller there is no problem, the image appears as intended.
I know that I can simply mirror the image to start out with in Corel, and it will appear after lasering as desired, but I would like to fix the issue. Does anyone know what's going on here? Thanks, Mark
CorelDraw X7 to LaserCad to LO-E5 mirrors image
marko53
Re: CorelDraw X7 to LaserCad to LO-E5 mirrors image
Check your "Page zero", "machine zero", and "Position relative" on LaserCad configuration. Make sure they match your HOME location. If not, mirror image could happen. After reset those setting, download again the image or it won't take into effect.
marko53
Thanks Marco. That did it.
Users browsing this forum: No registered users and 55 guests
