circle bug importing into Lasercut
Hydrops
Post by Hydrops »
Hi
I have this bug where importing dxf files into lasercut perfect circles are imported as squares, has anybody had this problem ?
I export the dxf files from aspire where I do all my laser and cnc jobs. Never had this problem before.
Tech support managed to replicate the problem but offered no solution apart from trying raycam or getting corel draw.
Would like to know if there might be a solution for this.
Regards
Re: circle bug importing into Lasercut
What version of DXF did you save it into?
Try save the file in 2004 AutoCad may fix the issue
Hydrops
Post by Hydrops »
Aspire doesn't have that option
Got coreldraw and it solves the problem
Thank you
Return to “DSP T9”
