Hi guys,
The door switch on the X7 (port 11 IN) - is it NO or NC ? Have seen some conflicting diagrams.
To make it clear - when door is closed - should the controller get closed circuit or open circuit to allow the machine to work ?
Cheers
Isaac
Door switch NO or NC
neuman5022
Re: Door switch NO or NC
Both are posible: you can set that level in the controller.. I use a proxy to detect the position of the lid/cap. This will output a 0 (zero) when the lid is closed.
