LaserCad not communicating
JerryLouisMartin
Cannot communicate with Laser using LASERCAD, get communication error? Fix or resolution?
Re: LaserCad not communicating
Is your controller new? can it be that you need to use RayCam instead?
How is your controller connected to your computer? Ethernet or USB..
JerryLouisMartin
JerryLouisMartin
Purchased in the last 18 months
JerryLouisMartin
I bought the Upgrade Kit in Feb 2016, Need RayCam?
JerryLouisMartin
USB, purchased in Feb 2016>
You can check the system info by using the LCD control. Click menu and scroll down to the last option. If see there is "LO" on hardware version,then you must run it with RayCam. Otherwise LaserCad
Make sure you have two cable connection from the LCD control unit to the interface box;CN1 and CN1. If you got one cable connected, the system won't function properly
JerryLouisMartin
Thanks I will check!
JerryLouisMartin
I have been unable to get LaserCad to communicate.
Can you provide me the link to RayCam.
Jerry
Jerry
Did you check the hardware version? And was it "LO xxx.." ?
If not, you have another problem..
To which USB-connector did you connect the computer? the one on top, or de one at the underside of the display-unit?
Wouldn't you try to connect it with the Ethernet of your computer? This connection is more stable and i think it's much faster too..
(configure your controller in the same range of your computer: ie. if your computer is 192.168.178.xx, make your controller 192,168.178.yy)
