Wiring Up Pneumatic Air Valve?
thejuggernaut
I have an X7 and am trying to figure out the best way to wire up the valve. I want it to open when the machine starts working and shut off when it is done. Can it be done without a relay. I know the controller outputs 24 volts, but it seems to do it the whole time the DSP is fired up.
thejuggernaut
Re: Wiring Up Pneumatic Air Valve?
Nevermind, I figured it out. Now I just need to find out if you can delay when it shuts down. I would like for it to run a few extra seconds after the project ends...
