Return home after job
seeigecannon
Is there any setting that I can change that will make the laser return to its home position after it has finished doing its job? Right now it just returns to whatever corner I started the job at, but I would prefer it move out of the way completely on its own. Thoughts?
jhuangupp
Re: Return home after job
Please do this in the LCD control panel:
Menu->common parameters setting-> work mode->go back position ->zero coordinate.
seeigecannon
Is that for the AWC-608? I don't remember seeing a settings like that.jhuangupp wrote:Please do this in the LCD control panel:
jhuangupp
Th feature is currently available to X7 DSP controller.
