MARCO - Just bought a new LO-800W Chiller and have questions
overkill71
Post by overkill71 »
Just got my LO-800W Chiller in and had a question, can the display be switched to Fahrenheit instead of Celsius? if so, how, the manual I found isn't very thorough. What is the wiring for the alarm? any Diagram to wire alarm?
Which light is D1 and which is D2? Upper D1? Lower D2? What is D1 for, Room Temp? D2 the set point?
Also, How do you switch between intelligent mode and constant mode?
How do you set the Set Temp? the temp you want it to hold?
Thanks !
overkill71
Re: MARCO - Just bought a new LO-800W Chiller and have quest
So no help from Light Object on an item they sell? Really......
Just hands on for a moment, we're working on the manual and will post it on the manual site very soon
overkill71
Thank you for the update.
overkill71
Thanks for the update!
