I 'm trying to figure where to wire in the water pressure cutoff switch.
I attached a picture of my power supply.
I have the following
P+ G K- K+ G IN 5v
Pressure WP-------???
Switch G----------------------------------
Water pressure switch
JerryLouisMartin
- laser power supply.PNG (1.25 MiB) Viewed 1934 times
seeigecannon
Re: Water pressure switch
JerryLouisMartin wrote:I 'm trying to figure where to wire in the water pressure cutoff switch.
P+ G K- K+ G IN 5v
Normally the switch would be between G (I think) and something labeled W. What I would recommend is putting it between your controller laser enable pin and the enable pin on the power supply. I would also recommend getting a 24V PSU from amazon or something because you will get better power out of that. Also, I have had a power supply from this manufacturer before and they were using un-named capacitors which ended up exploding. I suggest you give a electronics hobbyist a case of beer or something to get them replaced.
Users browsing this forum: No registered users and 56 guests
