Couple of important questions I'm sure someone can answer
WVJoe
Post by WVJoe »
Questions:
1 - I purchased the X7 upgrade kit and it came with an 18mm air assist head. I apparently need to get the mirror and lens for this as it was not included in the kit. I was looking through the lenses and see a bunch of different ones, one was a High quality 18mm ZnSe Focus lens (F50.8mm); Is the 18mm referring to the diameter of the lens? Is this the size I need for the 18mm air assist head that came in the kit? And, is the (F50.8mm) in the description, the focal distance from the lens to the material? I don’t know what to get.
2 – I also purchased one of the Z tables and am needing the thread size of the holes on the bottom plate for mounting it in the unit. Does anyone have that information available please so I can get the correct screws to mount the table?
Joseph Midjette Sr.
DonL
Re: Couple of important questions I'm sure someone can answe
Post by DonL »
WV Kokamo Joe wrote:Questions:
Joseph Midjette Sr.
A) The 18mm is the diameter, 50.8 is the focal length from the lens to the substrate (material) the longer the focal length - the bigger the beam and the deeper the beam so, for fine engraving or fine shallow cuts use a short focal length of 1 inch, for deep cuts and fast but not so fine engraving use a long 2.5 inch focal length... ir for a fixed height table, the standard 1.5 inch focal length
B) Marco can answer that or you can just use a thread gauge on the screws that came out... For me, I used double face tape and it works like a charm two strips on the bottom of the Z table and two on the sides of the top so it sticks to the X/Y stage noce and square and nothing vibrates, better than screwing around smile ;) If I need to remove it, slide a thin blade in and pry it gently off the tape and replace the tape after. :D
WVJoe
Post by WVJoe »
Joseph Midjette Sr.
Awesome! Thanks for the educational reply!
