Anywells 708plus
Telrad
Anywells 708plus
I was on another website and heard some information about the Anywells 708plus controller. Most notable features were preignition support for large wattage glass tubes and most exiting is greyscale engraving! I tried checking ot the anywells web site but the English translation is nonexistent.
Marco, do you have any information about this controller?
Re: Anywells 708plus
Don't expect too much from the greyscale feature. It is not done yet. It was me to ask the programmer (Li) to add the feature on LaserCad since two years ago. He did it and tried it but was not happy the result. He insisted that it was possible to make "3D" by laser. I talked to another DSP manufacturer (RD) and was told that to do 256 grey-scale and to achieve the 3D effect, only a RF laser tube is possible. If it is the reason you want to get the 708Plus, then I guess you will be disappointed. If it worked good, why wouldn't I carry it. Remember that Li and me are good friend and we're an alliance. He will listen to my advise should I come up some idea of new features.
Telrad
That's odd about greyscale needing an rf tube because I have an epilog legend 32 at home that I put a 40w glass tube and power supply on. It does greyscale perfectly fine and it gives me good 3D results. I'm just looking for a solution that will allow greyscale on my Chinese hardware.
Are you serious? !
Then, I need you to shoot me a video on the machine that is capable to do the 3D engraving and the 3D work if you can. I am going to show it to Li see if he can do it. It is because both Li and another DSP maker said that no CO2 laser could do the 3D engraving other than a RF laser. Probably Eplog found a new way to do it.
DonL
I also noticed they provide a USB and CAT5 port cable that plugs into the side of the controller to extend the ports to the case... A nice feature, Anyone know where I can get that cable? The 708C has the port but my kit did not have the cableTelrad wrote:I was on another website and heard some information about the Anywells 708plus controller. Most notable features were preignition support for large wattage glass tubes and most exiting is greyscale engraving! I tried checking ot the anywells web site but the English translation is nonexistent.
eBay? I bought mine there..DonL wrote:Anyone know where I can get that cable?
DonL
I have been searching every seller's store and don't see it listed separately, Do you have a vendor name by chance?Techgraphix wrote:eBay? I bought mine there..DonL wrote:Anyone know where I can get that cable?
Cheers!
Don
Telrad
Tech_Marco wrote:Are you serious? !![]()
I'll send a video when I can but my setup is using a 14 year old epilog legend 32. I have changed nothing on the epilog electronics. I just took off the old synrad laser and installed a glass tube 40w laser and power supply I bought off eBay about 4 years ago.
What would be the speed when doing 2.5D engraving?
First search hits:DonL wrote: Do you have a vendor name by chance?
http://www.ebay.com/itm/1FT-RJ45-Male-t ... SwbqpT25Sy
And
http://www.ebay.com/itm/USB-2-0-B-Femal ... Swa39UziTz
Keywords are "panel mount" and USB or Ethernet cable...
DonL
I ordered 4 of each, thanks, I also found a dual cable that plugs into the side connector of the 708c so all of my USB and Ethernet connections are sorted.... Cheers!Techgraphix wrote:First search hits:DonL wrote: Do you have a vendor name by chance?
