Steper Motor Controller Z-Table
litterbox99
Post by litterbox99 »
I just bought a 320/D40/K40 - 40W CO2 laser on ebay.
The Z-table was a POS. It had a twisty knob in the upper right
corner to lift the bed up and down with this primitive chain system.
Very poor construction and unusable. Not even close to being plane.
Then I saw this :
http://www.lightobject.com/Power-table- ... P722.aspx#
This is what I need !!!!
However, I do not want to use software to control this.
I would prefer an UP/DOWN toggle switch & a rheostat for
motor speed. Just a simple up/down circuit, but I have no
experience with steppers. Can someone point me into a direction ?
Todd
Re: Steper Motor Controller Z-Table
You may consider this board
http://www.lightobject.com/Stepping-mot ... -P729.aspx
Additional parts needed is a motor driver, push buttons, and a DC power supply.
litterbox99
Thanks LightObject !
I received your shipment and now have a working
Z table with your recommended parts.
I recall a video with this same setup but it had what
looked like limit switches mounted to a piece of plexi.
That setup would be a nice addition, but I don't recall
where I saw it.
Todd
litterbox99
I just found it !
viewtopic.php?f=16&t=2112
If this Plexi / Micro Switch setup were for sale... I'd buy it !
