Daughter board for Lo-R5 DSP conversion
gadman58
Post by gadman58 »
Doing a install of the LO R5 DSP thought i would make it easier to go back some times I break things. :)
Put in a a couple of PNP transistors and 5v relays, so the DSP thinks it is has NC limits but still using the original ones.
Most of the stuff I already had except the FFC connector. The green connectors are over kill and probably need double the 24v/GND connections.
Darn top print moved when I was putting it on.
