900x600 Frame Nuts
shanet94
900x600 Frame Nuts
Post by shanet94 »
My wife is putting the 900x600 frame kit together and almost got this put together yesterday but she missed a few brackets. Is their any easy way to get a nut in the channel without taking a bunch of it apart? Its this item:
http://www.lightobject.com/Aluminum-fra ... -P867.aspx
Shane
Re: 900x600 Frame Nuts
I don't know this frame but if you are referring to t-nuts: most of the t-nuts can be flipped in sideways.
If you use this type, you can place them without taking everything apart.
shanet94
Post by shanet94 »
Techgraphix wrote:I don't know this frame but if you are referring to t-nuts: most of the t-nuts can be flipped in sideways.
The attachment T-Nutensteine_Nutensteine_fuer_T-Nutenplatten_cnc_extra_C.jpg is no longer available
unfortunately they look like squares.
square nut
square nut
shanet94
Post by shanet94 »
FYI if you want a drop in nut for these frames, you can use this 5mm t-nut
http://www.amazon.com/gp/product/B00WW50JAM
works like a champ ;)
That's what you need, indeed..
The ones with the springloaded ball will stay in place more easy when you positioned them.. easy when you have to assemble non-horizontal parts.
