hi im doing and dsp upgrade with the lo-x7 but im a bit stuck with the wiring from the psu as all the diagrams i have and have seen show different letters to the ones i have on my psu which read G/P/L/G/IN/5V offset behind the plugs and on the plugs (P+/G)(K-/K+)(G/IN/5V) and another set of 4 that reads (24/G/5V/L) What i need to know is where the 3 wires go from the laser psu to the awc708c unit
i know which were the laser +and - but i am also a little worried as the size of the wire on the volt meter is much smaller than the laser neg wire will this be ok
wiring the old psu for dsp upgrade
mark seward
geartech
Re: wiring the old psu for dsp upgrade
I've got the same p/s you have I think.
Here is a pin out for that p/s
http://3dprintzothar.blogspot.com/2014/ ... -with.html
there is an image on this page that has the break out for the 4-6-4 connector p/s
I'm just about done with mine just have to do a little bit more wiring clean-up and
tweaking the setup. I think I'm going to leave the laser on-off sw in the safety loop.
The only thing I have to figure out is manual trigger for beam alignment after its all back together.
