Lately I have been getting the following message everytime I power up the DSP: "Continue to work after Powerout?"
I hit escape and the lcd returns to normal home screen. I shut down the same way I always have..but maybe I changed a setting on the controller - any suggestions?
"Continue to work after Powerout?" message SOLVED
funhawke
Re: "Continue to work after Powerout?" message
It means there is an unfinished job in your memory.. When you delete that job, the message is gone too..
Spleen
I have deleted all the jobs and formatted the memory thing (on the download screen on the pc side) more than once and still always get this message, I have for months.
Techgraphix wrote:It means there is an unfinished job in your memory.. When you delete that job, the message is gone too..
Re: "Continue to work after Powerout?" message SOLVED
And what if you say yes to continue the job? (without material and way off-focus)
