Hello All,
Does anyone know where I can get a 90 degree fitting for the light object air nozzle? I need one for the head. Any idea what the tpi on the stock one is? If I have to tap it to a new size, I'm okay with that. I'm using the 5x8 silicon tube that LO sells.
-Tim
Air fitting
Re: Air fitting
try to find: Norgren PNEUFIT C C0A510605. This has a M5 screw but only a 6mm pushfitting.. Maybe you can make the last end (from over the bridge to the head) 6mm tube.. It's more flexible too..
I can order one, if you can't find it, and ship it to you in an envelope. The pricetag for this item is 4.29Euro. I think an envelope to worldwide (50-100 grammes) will be ~ 3.50 euro.
Tim
Re: Air fitting
Thanks for the offer, I think I have this worked out. I'll update this when I get the part installed.
-Tim
-Tim
