?????? x7 dsp controller manual
glow1980
Post by glow1980 »
hi all iam new here and looking at the x7 dsp controller and see the build manual but is they a user manual at all ?]
weeb
Re: ?????? x7 dsp controller manual
Post by weeb »
If there is an X7 manual, I certainly couldn't find it. What I did was download the 608 manual and read it top to bottom probably 3 times so that I could get an idea of the terminology. Although the X7 and the 608 look different they are quite similar under the hood, for instance: say start speed and space factor, they both mean the same no matter which interface you are looking at. All the parameters that sound like klingon to me are explained in the 608 manual so I was able to adapt to the X7
quite easily and this is my first laser so I had to learn everything from scratch. I learn new things about the laser and controller everyday as I progress. Hope this helps. Oh and welcome to the forums. smile
glow1980
Post by glow1980 »
hi thanks for getting back to me
do u have a link to the 608 manual so I could have a look at it thanks
Wasn't there any paper-manual with your X7? (how to connect it..)
Else: i'm busy making some drawings how to connect several connectors on the X7, including limit-sensors, LPSU etc.
A few functions are nowhere to find, like OUT3-6 and IN1-4.. Think i have to ask some manufacturers of similar units.
Or Marco can ask through his channels.. I would appreciate that ;-)
Most of the connections are clear to me and i will involve these in my drawings but there are more...
For manuals: google AWC608 Manual and sure you will find plenty.. They are all quite similar..
(unfortunately no one found for the AWC708C/X7)
