Setting home to 0 in centre of table -SOLVED
funhawke
Post by funhawke »
In LaserCad is there a way to set where home will be. Still having problems with the table going to far on x and y but when I monkey with it - it seems to always put "0" in the centre of the table?
Re: Setting home to 0 in centre of table
Are you talking about "HOME"(where limit switches is installed) or "Origin" where laser head start to do job at?
You can set HOME at one of the corner; Top Left,Top Right, Bottom Left, and Bottom Right.
For Origin, you press "Origin" on LCD control panel to set the location of the origin
funhawke
Post by funhawke »
Thanks Marco - that is exactly what I was looking for. Home and Origin
