What is the motor in the 600x400 Z table?
sentrol
Post by sentrol »
I want to know the model name of the motor in the Stainless steel Motorized Z table 600x400.
Is there someone who knows the motor informations?
Also, What can I use the motor driver?
Re: What is the motor in the 600x400 Z table?
Hello:
You can use one of this driver to power up the Z table
http://www.lightobject.com/2-Phase-78A- ... -P454.aspx
It is two a two phase motor and you may set current to 7.2A. If it got very hot, then you can lower down the current.
DC power should be 36V to 42V
Return to “Others”
